[gdal-dev] S57 dataset boundary issue
Nikhil Sai Parupalli nikhil.parupalli at iictechnologies.com
Mon Oct 8 22:28:38 PDT 2012
HI All,
Thanks for the reply in below data
  NAME_RCNM (IntegerList) = (7:130,130,130,130,130,130,130)
   NAME_RCID (IntegerList) = (7:691,391,690,52,1336,1503,1512)
   ORNT (IntegerList) = (7:2,2,2,2,1,1,1)
   USAG (IntegerList) = (7:1,1,1,1,1,1,1)
   MASK (IntegerList) = (7:255,255,255,255,255,255,255)
 RCID 691 ORNT has  2 and USAG is 1 based on this data we could identify that RCID 691 is of exterior boundary with reverse direction.
So if I have 1000 RCID in  NAME_RCID which is vise versa for the above condition I need to display that RCIDS list as errors.
So it makes 1000 conditional checks hence reducing performance.
Please let us know further.
Nikhil,
I don't know why you don't see it.  I see it fine on the "Edge"
layer which contains the linestring vector objects.
eg.
  OGRFeature(Edge):18
   RCNM (Integer) = 130
   RCID (Integer) = 19
   RVER (Integer) = 1
   RUIN (Integer) = 1
   NAME_RCNM_0 (Integer) = 120
   NAME_RCID_0 (Integer) = 21
   ORNT_0 (Integer) = 255
   USAG_0 (Integer) = 255
   TOPI_0 (Integer) = 1
   MASK_0 (Integer) = 255
   NAME_RCNM_1 (Integer) = 120
   NAME_RCID_1 (Integer) = 20
   ORNT_1 (Integer) = 255
   USAG_1 (Integer) = 255
   TOPI_1 (Integer) = 2
   MASK_1 (Integer) = 255
   LINESTRING (60.775 -32.6249972)
> I have one more question:
> How do we find  area outer boundaries are encoded clockwise based
> on Orientation or USAG.
> here when I retrieve S57 dataset I get multiple ORNT values for a single object.
I am not aware of any definition of outer ring winding direction.
I think the ORNT field values you see on polygons are indicating
which direction the edges were used in when composing the ring(s)
of the polygon.
So in the above feature, RCID 691 is used with orientation "2",
usage "1" and mask "255".
Best regards,
Thanks and Regards
Note: Do not print this email until and unless it is really required. Save paper , stay Green
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121009/faaa1d59/attachment.html>
