[gdal-dev] S57 dataset boundary issue
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 9 09:25:29 PDT 2012
On Mon, Oct 8, 2012 at 10:28 PM, Nikhil Sai Parupalli <
nikhil.parupalli at iictechnologies.com> wrote:
> HI All,
> Thanks for the reply in below data
> NAME_RCNM (IntegerList) = (7:130,130,130,130,130,130,130)
> NAME_RCID (IntegerList) = (7:691,391,690,52,1336,1503,1512)
> ORNT (IntegerList) = (7:2,2,2,2,1,1,1)
> USAG (IntegerList) = (7:1,1,1,1,1,1,1)
> MASK (IntegerList) = (7:255,255,255,255,255,255,255)
> RCID 691 ORNT has 2 and USAG is 1 based on this data we could identify
> that RCID 691 is of exterior boundary with reverse direction.
> So if I have 1000 RCID in NAME_RCID which is vise versa for the above
> condition I need to display that RCIDS list as errors.
> So it makes 1000 conditional checks hence reducing performance.
> Please let us know further.
Nikhil,
I'm afraid I don't follow your point. Are you trying to
do some sort of ring orientation validation and identify
ones that don't match your expectations? And you
are concerned about the performance cost?
I don't know why you are doing this, and if you
are, I'm not sure what I or others can do about
the performance cost of checking.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121009/e67d1341/attachment-0001.html>
