[gdal-dev] [ OGR SQL: Excecuting select where column name starts with "_" SO: Windows 7, GDAL/OGR 1.9.x
Gabriel Fusca
gabrielfusca at suremptec.com.ar
Tue Oct 9 13:35:56 PDT 2012
I´m getting a sql parsing error when I tried to execute a query to a
shapefile where column name starts with "_".
When i execute a query like : ogrinfo Provincias.shp -sql "SELECT * FROM
Provincias WHERE tipo = 1"
INFO: Open of `Provincias.shp'
using driver `ESRI Shapefile' successful.
Layer name: Provincias
Geometry: Line String
Feature Count: 21
Extent: (309062.030000, 3895521.900000) - (2039227.590000, 7591083.240000)
Layer SRS WKT:
PROJCS["500K",
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_84",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",1000000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-64.0],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Latitude_Of_Origin",-90.0],
UNIT["Meter",1.0]]
_tipo_Area: Integer (10.0)
_desc_Area: String (1.0)
tipo: Integer (10.0)
OGRFeature(Provincias):29
ID (String) = 0
_tipo_Area (Integer) = 1
_desc_Area (String) = (null)
tipo (Integer) = 1
LINESTRING (873405.76 7463549.34,873313.54 7463695.39,872765.09
7465104.71,872
623.98 7465495.26)
But when i want to execute a query like "SELECT * FROM Provincias WHERE
_tipoArea = 1"
WHERE _tipo_Area = 1"
ERROR 1: SQL Expression Parsing Error: syntax error
Any ideas on how to get around this?
Best regards,
Gabriel Fusca
SUR Emprendimientos Tecnológicos
Perú 345 Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
http://www.suremptec.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121009/7be36719/attachment.html>
