[gdal-dev] [ OGR SQL: Excecuting select where column name starts with "_" SO: Windows 7, GDAL/OGR 1.9.x
Etienne Tourigny
etourigny.dev at gmail.com
Thu Oct 11 14:06:05 PDT 2012
try enclosing the column with single or double quotes?
On Tue, Oct 9, 2012 at 5:35 PM, Gabriel Fusca
<gabrielfusca at suremptec.com.ar> wrote:
> Hi,
> I´m getting a sql parsing error when I tried to execute a query to a
> shapefile where column name starts with "_".
> When i execute a query like : ogrinfo Provincias.shp -sql "SELECT * FROM
> Provincias WHERE tipo = 1"
> INFO: Open of `Provincias.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: Provincias
> Geometry: Line String
> Feature Count: 21
> Extent: (309062.030000, 3895521.900000) - (2039227.590000, 7591083.240000)
> Layer SRS WKT:
> PROJCS["500K",
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_84",6378137.0,298.257223563]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.017453292519943295]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",1000000.0],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",-64.0],
> PARAMETER["Scale_Factor",1.0],
> PARAMETER["Latitude_Of_Origin",-90.0],
> UNIT["Meter",1.0]]
> _tipo_Area: Integer (10.0)
> _desc_Area: String (1.0)
> tipo: Integer (10.0)
> OGRFeature(Provincias):29
> ID (String) = 0
> _tipo_Area (Integer) = 1
> _desc_Area (String) = (null)
> tipo (Integer) = 1
> LINESTRING (873405.76 7463549.34,873313.54 7463695.39,872765.09
> 7465104.71,872
> 623.98 7465495.26)
> But when i want to execute a query like "SELECT * FROM Provincias WHERE
> _tipoArea = 1"
> WHERE _tipo_Area = 1"
> ERROR 1: SQL Expression Parsing Error: syntax error
> Any ideas on how to get around this?
> Best regards,
> Gabriel Fusca
> SUR Emprendimientos Tecnológicos
> Perú 345 Piso 5to Oficina "B" (C1067AAG)
> Ciudad de Buenos Aires, Argentina
> Tel. +54 (11) 4342-2976/84
> http://www.suremptec.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
