[gdal-dev] Open Source GIS Raster Viewer
Nikhil Sai Parupalli nikhil.parupalli at iictechnologies.com
Fri Oct 12 06:21:04 PDT 2012
Hey Kishore,
We can use DotSpatial library that provides Map control wjer we can display map and ot has standard ZoomIn,ZoomOut ,PAN etc...
I am using the same in my application which is working fine.
Thanks and Regards
Note: Do not print this email until and unless it is really required. Save paper , stay Green
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] on behalf of kishore Borra [kishoreborra at gmail.com]
Sent: Friday, October 12, 2012 6:22 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Open Source GIS Raster Viewer
Hi All,
we are implementing support of elevation processing of various raster images in a standalone desktop Viewer using opensource.
we are using GDAL library to support performing various operations like hillshade, slope, aspect map & color coded relief.
I would like to know your suggestions on what opensource control can be used as a map control so that I can load various type of processed raster images into it. I need to provide the user with the coordinates readout information and standard zoom In, zoom out & zoom By area operations.
I should also be able to read the elevation info from the displayed raster and display the same in the status bar.
Please suggest.
Regards,
Kishore.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121012/ce69a92b/attachment.html>
