[gdal-dev] Open Source GIS Raster Viewer
Siebe Bosch
siebe at hydroconsult.nl
Fri Oct 12 07:17:29 PDT 2012
Hi Kishore,
You can also use the Mapwindow OCX map control.
Here's a link to some tutorials that cover the use of this library
http://www.mapwindow.org/tutorials/
Kind regards,
Siebe Bosch
On 12-10-12 15:21, Nikhil Sai Parupalli wrote:
> Hey Kishore,
> We can use DotSpatial library that provides Map control wjer we can
> display map and ot has standard ZoomIn,ZoomOut ,PAN etc...
> I am using the same in my application which is working fine.
> Thanks and Regards
> Note: Do not print this email until and unless it is really required.
> Save paper , stay Green
> *From:* gdal-dev-bounces at lists.osgeo.org
> [gdal-dev-bounces at lists.osgeo.org] on behalf of kishore Borra
> [kishoreborra at gmail.com]
> *Sent:* Friday, October 12, 2012 6:22 PM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* [gdal-dev] Open Source GIS Raster Viewer
> Hi All,
> we are implementing support of elevation processing of various raster
> images in a standalone desktop Viewer using opensource.
> we are using GDAL library to support performing various operations
> like hillshade, slope, aspect map & color coded relief.
> I would like to know your suggestions on what opensource control can
> be used as a map control so that I can load various type of processed
> raster images into it. I need to provide the user with the coordinates
> readout information and standard zoom In, zoom out & zoom By area
> operations.
> I should also be able to read the elevation info from the displayed
> raster and display the same in the status bar.
> Please suggest.
> Regards,
> Kishore.
> gdal-dev mailing list
Hydroconsult
Lulofsstraat 55, unit 47
2521 AL Den Haag
The Netherlands
web: http://www.hydroconsult.nl
e-mail: siebe at hydroconsult.nl
phone: +31(0)70 250 0580
mobile: +31(0)6 17 682 689
actief lid van WaterForce.nu, het netwerk van
zelfstandige professionals in het waterbeheer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121012/73251129/attachment.html>
