[gdal-dev] Open Source GIS Raster Viewer
Tyler Mitchell tyler.mitchell at actian.com
Fri Oct 12 09:37:51 PDT 2012
I'd recommend the OSSIM platform which as various additional image processing utilities that you will find useful.  If you just need desktop GIS viewing functionality, I suggest QGIS which will read all GDAL image formats fine and provide all of what you talk about.
Tyler
http://trac.osgeo.org/ossim/
http://qgis.org
On 2012-10-12, at 5:52 AM, kishore Borra wrote:
> Hi All,
> we are implementing support of elevation processing of various raster images in a standalone desktop Viewer using opensource.
> we are using GDAL library to support performing various operations like hillshade, slope, aspect map & color coded relief.
> I would like to know your suggestions on what opensource control can be used as a map control so that I can load various type of processed raster images into it. I need to provide the user with the coordinates readout information and standard zoom In, zoom out & zoom By area operations.
> I should also be able to read the elevation info from the displayed raster and display the same in the status bar.
> Please suggest.
> Regards,
> Kishore.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Tyler Mitchell
Engineering Director
Actian Corporation
MOBILE 250-303-1831
SKYPE spatialguru
www.actian.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121012/2e9ff58e/attachment.html>
