[gdal-dev] Combine aerial images
Frank Broniewski brfr at metrico.lu
Fri Oct 12 08:00:34 PDT 2012
I have a directory with appr. 2800 aerial images, each 1kmx1km. I'm
using this source for a Mapserver WMS layer. Unfortunately the amount of
data to process is way too much for a Mapserver WMS service.
Now I want to create larger overview images where the aerial images are
combined together. The route I wanted to was
1) build a VRT from the images
2) use gdal_translate to get a new geotiff with a smaller size (pixel wise)
Is this a valid route to go?
Many thanks,
Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
