[gdal-dev] Combine aerial images
Nikolaos Hatzopoulos
nhatzop at gmail.com
Fri Oct 12 15:42:34 PDT 2012
put a second server and have the 1400 image to the one and the other 1400
to the other :)
-- Nikos
On Fri, Oct 12, 2012 at 8:00 AM, Frank Broniewski <brfr at metrico.lu> wrote:
> Hi,
> I have a directory with appr. 2800 aerial images, each 1kmx1km. I'm using
> this source for a Mapserver WMS layer. Unfortunately the amount of data to
> process is way too much for a Mapserver WMS service.
> Now I want to create larger overview images where the aerial images are
> combined together. The route I wanted to was
> 1) build a VRT from the images
> 2) use gdal_translate to get a new geotiff with a smaller size (pixel wise)
> Is this a valid route to go?
> Many thanks,
> Frank
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> technologies d'information géographique
> rue des Romains 36
> L-5433 NIEDERDONVEN
> tél.: +352 26 74 94 - 28
> fax.: +352 26 74 94 99
> http://www.metrico.lu
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121012/d7f7b940/attachment.html>
