[gdal-dev] Setting DataType in ReadAsArray
elliott at cpi.com
elliott at cpi.com
Tue Oct 16 14:53:01 PDT 2012
> Il 16/10/2012 22.05, elliott at cpi.com ha scritto:
>> Hello,
>> Does anybody know of a way to set the data type in the call ReadAsArray.
>> It is currently reading a field as an unsigned int and it needs to be
>> read
>> as a signed int.
> Hi,
> ReadAsArray returns substantially a numpy array, so you can use np
> functions and methods of conversions between data types [1]. Finally,
> the simplest way consists into using the .astype() method. Hope this
> helps!
> Cheers,
> Antonio
> [1] http://docs.scipy.org/doc/numpy/user/basics.types.html
> Antonio Falciano
> http://www.linkedin.com/in/antoniofalciano
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Thanks, perfect! Exactly what I was looking for.
