[gdal-dev] gdalinfo -stats Misses invalid data value in ENVI header
Peter Willis
pwillis at aslenv.com
Fri Oct 19 15:06:54 PDT 2012
Hello,
I am seeing that you are correct that the 'no data value' is being read in each case.
Perhaps my interpretation of the problem appears incorrect.
Look, however at the 'Metadata:' statistics.
Both files have assigned -999 to 'No Data Value' but 'STATISTICS_MINIMUM' for one file shows -999 (??).
This means the values are not being ignored for the purpose of calculating statistics.
--THE BAD FILE--
Band 2 Block=2178x1 Type=Float32, ColorInterp=Undefined
Description = Band 2
Min=-999.000 Max=12.250
Minimum=-999.000, Maximum=12.250, Mean=-946.817, StdDev=222.404
NoData Value=-999
Metadata:
STATISTICS_MINIMUM=-999
STATISTICS_MAXIMUM=12.25
STATISTICS_MEAN=-946.81678963104
STATISTICS_STDDEV=222.4036660914
---THE GOOD FILE---
Band 2 Block=1677x1 Type=Float32, ColorInterp=Undefined
Description = Band Math (Band Math (Band Math (1996_104 Landsat-4/5 TM :Surface Temperature Sensor:6:LSatThermalCube_96-98.img):LSatThermalCube_96-98_float.img):LSatThermalCube_96-98_float_cmsk.img)
Min=0.250 Max=12.250
Minimum=0.250, Maximum=12.250, Mean=1.379, StdDev=0.995
NoData Value=-999
Metadata:
STATISTICS_MINIMUM=0.25
STATISTICS_MEAN=1.3787828985307
STATISTICS_STDDEV=0.99545771926881
Note the difference in stats calculations.
Peter
