[gdal-dev] gdalinfo -stats Misses invalid data value in ENVI header
Even Rouault even.rouault at mines-paris.org
Fri Oct 19 15:10:09 PDT 2012
Le vendredi 19 octobre 2012 23:57:01, Peter Willis a écrit :
> Hello,
> At step #6,  gdalinfo -stats reports data stats with the -999 values
> calculated into the min/max/mean/stdev.
> Band 2 Block=2178x1 Type=Float32, ColorInterp=Undefined
>   Description = Band 2
>   Min=-999.000 Max=12.250
>   Minimum=-999.000, Maximum=12.250, Mean=-946.817, StdDev=222.404
>   NoData Value=-999
>   Metadata:
>     STATISTICS_MINIMUM=-999
>     STATISTICS_MAXIMUM=12.25
>     STATISTICS_MEAN=-946.81678963104
>     STATISTICS_STDDEV=222.4036660914
Ok, indeed that's not expected.
Well, perhaps you could first check if there is no .aux.xml file that would
contain bad values. And if so, delete it before running again gdalinfo -stats.
Other than that, I've no more idea without having access to the .img file
itself.
