[gdal-dev] gdaltransform - output into textfile
Hugo Benicio
hbobenicio at gmail.com
Tue Oct 23 07:10:56 PDT 2012
if you remove the output redirection >"Grid.txt", what does it do?
gdaltransform -s_srs EPSG:4326 -t_srs EPSG:3857 < "WGS84.txt"
Does it print the output on you console/terminal? gdaltransform is actually
generating an output?
(You redirection syntax seems ok)
On Tue, Oct 23, 2012 at 9:49 AM, Ernest Menville
<menville.ernest at gmail.com>wrote:
> Hi,
> I have a problem redirecting the output of gdaltransform into a text file.
> The output file is always empty.
> my code:
> gdaltransform -s_srs EPSG:4326 -t_srs EPSG:3857 < "WGS84.txt" >"Grid.txt"
> with "WGS84.txt":
> 10.590820 46.935261
> 10.898438 46.935261
> 10.898438 46.785016
> 10.590820 46.785016
> The file "Grid.txt" is created, but empty.
> Can anybody help me?
> cheers,
> Ernest
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121023/944d086a/attachment.html>
