[gdal-dev] gdaltransform - output into textfile
Ernest Menville menville.ernest at gmail.com
Tue Oct 23 07:13:57 PDT 2012
if you remove the output redirection >"Grid.txt", what does it do?
> gdaltransform -s_srs EPSG:4326 -t_srs EPSG:3857 < "WGS84.txt"
> Does it print the output on you console/terminal? gdaltransform is
> actually generating an output?
> (You redirection syntax seems ok)
Yes, the output without redirection is correct:
1178964.68948322 5931513.41439894 0
1213208.56860206 5931513.41439894 0
1213208.56860206 5907053.53893779 0
1178964.68948322 5907053.53893779 0
But I can't save it to a file.
regards,
Ernest
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121023/739aaf92/attachment.html>
