[gdal-dev] problem with compiling grass with gdal
Even Rouault even.rouault at mines-paris.org
Wed Oct 24 11:43:55 PDT 2012
Le mardi 23 octobre 2012 21:36:48, Martin Landa a écrit :
> Hi Even,
> 2012/10/23 Even Rouault <even.rouault at mines-paris.org>:
> > Could you diff the output of the generated GDALmake.opt in trunk and 1.9
> > ? And also the same for config.log ?
> thanks for the quick answer, the files attached.
Hum, still nothing obvious. Perhaps retry to configure trunk --without-libxml2
, but I'm quite skeptical it will change anything.
Perhaps try to diff the output of ldd libgdal.so ??
> Martin
