[gdal-dev] problem with compiling grass with gdal
Martin Landa landa.martin at gmail.com
Wed Oct 24 13:22:01 PDT 2012
2012/10/24 Even Rouault <even.rouault at mines-paris.org>:
> Hum, still nothing obvious. Perhaps retry to configure trunk --without-libxml2
> , but I'm quite skeptical it will change anything.
right, `--without-xml2` didn't help. In other worlds there is no difference.
> Perhaps try to diff the output of ldd libgdal.so ??
Apparently libstdc++.so.6 is missing in trunk.
--- ldd-1-9.out 2012-10-24 22:20:50.984698378 +0200
+++ ldd-trunk.out       2012-10-24 22:20:43.092698166 +0200
@@ -12,14 +12,15 @@
        libpq.so.5 => /usr/lib/libpq.so.5
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
+       libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6
        librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2
+       libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3
        libcurl.so.4 => /usr/lib/x86_64-linux-gnu/libcurl.so.4
        libOpenCL.so.1 => /usr/lib/x86_64-linux-gnu/libOpenCL.so.1
-       libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
-       libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6
-       libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6
+       libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1
+       libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6
        libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7
        libhdf5_hl.so.7 => /usr/lib/libhdf5_hl.so.7
        libhdf5.so.7 => /usr/lib/libhdf5.so.7
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
