[gdal-dev] gdaltransform - output into textfile
Even Rouault
even.rouault at mines-paris.org
Fri Oct 26 07:26:25 PDT 2012
Selon Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>:
> Even Rouault <even.rouault <at> mines-paris.org> writes:
> > For the record, unfortuanetely it won't help you much, but I don't
> reproduce
> > the issues you're facing. The gdaltransform -s_srs EPSG:4326 -t_srs
> EPSG:3857
> > < "WGS84.txt" >"Grid.txt" command just works fine for me. Perhaps an
> issue with
> > your setup ?
> He is not the only one. I tried the command too and it does create the
> grid.txt file but it remains empty, just as described.
> My GDAL version is development build from 24th October (MSVC2010 x64).
I had only tested with Linux. I've just tested with custom builds on Windows 32
bit with MSVC 7.1 and 9.0 and still don't reproduce any issue. Mysterious.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
