[gdal-dev] gdaltransform - output into textfile
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Fri Oct 26 04:10:11 PDT 2012
Even Rouault <even.rouault <at> mines-paris.org> writes:
> For the record, unfortuanetely it won't help you much, but I don't
reproduce
> the issues you're facing. The gdaltransform -s_srs EPSG:4326 -t_srs
EPSG:3857
> < "WGS84.txt" >"Grid.txt" command just works fine for me. Perhaps an
issue with
> your setup ?
He is not the only one. I tried the command too and it does create the
grid.txt file but it remains empty, just as described.
My GDAL version is development build from 24th October (MSVC2010 x64).
-Jukka Rahkonen-
