[gdal-dev] Compile GDAL with HDF4 and Shapefile-Support (64bit)
David1980
dleimbach at zebris.com
Fri Sep 7 04:42:54 PDT 2012
Maybe I need an older version of the C#-GDAL-bindings in order to use the
version included in FW-Tools ?
Since the code for loading GDAL is quite simple and works with newer
GDAL-versions (32 / 64 bit) that seems to be the most likely reason for me.
Has anybody used (version 1.7 32bit / FW-Tools-)GDAL in C# (or another
Visual Studio language) with raster- and vector-graphics at the same time ?
Then it might be helpfull for me to know the version and source of the
bindings used. :)
View this message in context: http://osgeo-org.1560.n6.nabble.com/Compile-GDAL-with-HDF4-and-Shapefile-Support-64bit-tp4998275p5000403.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
