[gdal-dev] gdal_wrap dll
Neelima Emmani neelima.emmani at iictechnologies.com
Mon Sep 10 02:13:49 PDT 2012
Hi Tamas,
Agreeing with you . I just gave a test with a small piece of code.Code goes as below -
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using OSGeo.GDAL;
using OSGeo.OGR;
using OSGeo.OSR;
namespace test_10_09_2012
    class Program
        static void Main(string[] args)
            OSGeo.GDAL.Gdal.AllRegister();
            String filename = @"xxxxxx.000";
            OSGeo.GDAL.Dataset ds = OSGeo.GDAL.Gdal.Open(filename, OSGeo.GDAL.Access.GA_ReadOnly);
            if (ds == null)
            Console.WriteLine("Can't open " + filename);
                    System.Environment.Exit(-1);
            Console.WriteLine("S57 dataset parameters:");
            Console.WriteLine("  Projection: " + ds.GetProjectionRef());
            OSGeo.GDAL.Driver drv = ds.GetDriver();
            if (drv == null)
                    Console.WriteLine("Can't get driver.");
                Console.WriteLine("Using driver " + drv.LongName);
 This throws me an exception in reading the file format. It says that it is not a recognized as a supported  file format .
Do you have any idea.
With Regards,
Neelima Emmani
Sent: Monday, September 10, 2012 1:20 PM
To: Neelima Emmani
Subject: Re: [gdal-dev] gdal_wrap dll
gdal_wrap.dll is not a managed assembly, you should not set reference to this dll.
gdal_csharp.dll loads gdal_wrap.dll internally (assuming it's location is added to the PATH environment setting)
Best regards,
Tamas
2012/9/10 Neelima Emmani <neelima.emmani at iictechnologies.com<mailto:neelima.emmani at iictechnologies.com>>
Hi All,
I am trying to get gdal for c#. For that, I have taken gdal binaries from the below link
 http://www.gisinternals.com/sdk/.<http://www.gisinternals.com/sdk/> As I am using Microsoft Visual Studio 9.0 and the system is windows 64 bit, I chose the compiler msvc2008(win64)-development.From the list of downloads under this link , I chose gdal-20dev-1500-x64-core.msi and  gdal-20dev-1500-x64-ecw.msi. These were installed under the c:/program files with a folder name GDAL. I have my visual studio under c:/program files(x86). And then , I have set my system environment path to c:/program files/GDAL.
After all this, I opened a new c# console application where i was successful in adding references like gdal_csharp, ogr_csharp, osr_csharp but could not add gdal_wrap.dll. The system is popping me up with the following error
A reference to 'C:\Program Files\GDAL\gdal_wrap.dll' could not be added. Please make sure that the file is accessible, and that it is a valid assembly or COM component.
Can anyone suggest me how to add this dll to my project. Do i need to do anything to get it work?
Awaiting reply.
With Regards,
Neelima Emmani
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120910/d756e3a5/attachment-0001.html>
