[gdal-dev] gdal_wrap dll
Tamas Szekeres
szekerest at gmail.com
Mon Sep 10 02:24:47 PDT 2012
How does ogrinfo recognize this file?
As far as I remember s57 requires the GDAL_DATA environment setting, for
example:
Gdal.SetConfigOption("GDAL_DATA", "path to gdal-data");
Best regards,
Tamas
2012/9/10 Neelima Emmani <neelima.emmani at iictechnologies.com>
> Hi Tamas,
> Agreeing with you . I just gave a test with a small piece of code.Code
> goes as below -
> using System;
> using System.Collections.Generic;
> using System.Linq;
> using System.Text;
> using OSGeo.GDAL;
> using OSGeo.OGR;
> using OSGeo.OSR;
> namespace test_10_09_2012
> class Program
> static void Main(string[] args)
> OSGeo.GDAL.Gdal.AllRegister();
> String filename = @"xxxxxx.000";
> OSGeo.GDAL.Dataset ds = OSGeo.GDAL.Gdal.Open(filename,
> OSGeo.GDAL.Access.GA_ReadOnly);
> if (ds == null)
> Console.WriteLine("Can't open " + filename);
> System.Environment.Exit(-1);
> Console.WriteLine("S57 dataset parameters:");
> Console.WriteLine(" Projection: " + ds.GetProjectionRef());
> OSGeo.GDAL.Driver drv = ds.GetDriver();
> if (drv == null)
> Console.WriteLine("Can't get driver.");
> Console.WriteLine("Using driver " + drv.LongName);
> This throws me an exception in reading the file format. It says that it
> is not a recognized as a supported file format .
> Do you have any idea.
> With Regards,
> Neelima Emmani
> *From:* Tamas Szekeres [szekerest at gmail.com]
> *Sent:* Monday, September 10, 2012 1:20 PM
> *To:* Neelima Emmani
> *Subject:* Re: [gdal-dev] gdal_wrap dll
> Hi,
> gdal_wrap.dll is not a managed assembly, you should not set reference to
> this dll.
> gdal_csharp.dll loads gdal_wrap.dll internally (assuming it's location is
> added to the PATH environment setting)
> Best regards,
> Tamas
>> Hi All,
>> I am trying to get gdal for c#. For that, I have taken gdal binaries from
>> the below link
>> http://www.gisinternals.com/sdk/. <http://www.gisinternals.com/sdk/> As
>> I am using Microsoft Visual Studio 9.0 and the system is windows 64 bit, I
>> chose the compiler msvc2008(win64)-development.From the list of downloads
>> under this link , I chose gdal-20dev-1500-x64-core.msi and
>> gdal-20dev-1500-x64-ecw.msi. These were installed under the c:/program
>> files with a folder name GDAL. I have my visual studio under c:/program
>> files(x86). And then , I have set my system environment path to c:/program
>> files/GDAL.
>> After all this, I opened a new c# console application where i was
>> successful in adding references like gdal_csharp, ogr_csharp, osr_csharp
>> but could not add gdal_wrap.dll. The system is popping me up with the
>> following error
>> A reference to 'C:\Program Files\GDAL\gdal_wrap.dll' could not be added.
>> Please make sure that the file is accessible, and that it is a valid
>> assembly or COM component.
>> Can anyone suggest me how to add this dll to my project. Do i need to do
>> anything to get it work?
>> Awaiting reply.
>> With Regards,
>> Neelima Emmani
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120910/9b5b300b/attachment.html>
