[gdal-dev] Perl Binding Documentation for previous releases -->404
Ethan Alpert
ealpert at digitalglobe.com
Wed Sep 19 13:41:26 PDT 2012
Thanks!
Indeed to get to the perl bindings I always start at:
http://trac.osgeo.org/gdal/wiki/GdalOgrInPerl
and follow the link:
http://geoinformatics.aalto.fi/doc/Geo-GDAL/html/
that page has the bad link.
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Wednesday, September 19, 2012 1:15 PM
To: gdal-dev at lists.osgeo.org; Ari Jolma
Subject: Re: [gdal-dev] Perl Binding Documentation for previous releases -->404
Le mercredi 19 septembre 2012 20:43:39, Ethan Alpert a écrit :
> Getting page not found for:
> http://geoinformatics.tkk.fi/doc/Geo-GDAL-1.8/html/index.html
I guess you reached that link from http://geoinformatics.aalto.fi/doc/Geo-
GDAL/html/ that is linked from http://trac.osgeo.org/gdal/wiki/GdalOgrInPerl ?
So, I tried the following http://geoinformatics.aalto.fi/doc/Geo-
GDAL-1.8/html/index.html and it seems to work
I believe that Ari maintains that site.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
