[gdal-dev] Perl Binding Documentation for previous releases -->404
Ari Jolma ari.jolma at gmail.com
Thu Sep 20 01:41:24 PDT 2012
Ethan and others,
We're in the process of moving everything from geoinformatics.tkk.fi to
geoinformatics.aalto.fi. TKK became a part of Aalto a couple of years ago.
Thanks for the info on bad links.
Ari
19.9.2012 23:41, Ethan Alpert kirjoitti:
> Thanks!
> Indeed to get to the perl bindings I always start at:
> http://trac.osgeo.org/gdal/wiki/GdalOgrInPerl
> and follow the link:
> http://geoinformatics.aalto.fi/doc/Geo-GDAL/html/
> that page has the bad link.
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
> Sent: Wednesday, September 19, 2012 1:15 PM
> To: gdal-dev at lists.osgeo.org; Ari Jolma
> Subject: Re: [gdal-dev] Perl Binding Documentation for previous releases -->404
> Le mercredi 19 septembre 2012 20:43:39, Ethan Alpert a écrit :
>> Getting page not found for:
>> http://geoinformatics.tkk.fi/doc/Geo-GDAL-1.8/html/index.html
> I guess you reached that link from http://geoinformatics.aalto.fi/doc/Geo-
> GDAL/html/ that is linked from http://trac.osgeo.org/gdal/wiki/GdalOgrInPerl ?
> So, I tried the following http://geoinformatics.aalto.fi/doc/Geo-
> GDAL-1.8/html/index.html and it seems to work
> I believe that Ari maintains that site.
> gdal-dev mailing list
> This electronic communication and any attachments may contain confidential and proprietary
> information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
> responsible for delivering this communication to the intended recipient, or if you have received
> this communication in error, please do not print, copy, retransmit, disseminate or
> otherwise use the information. Please indicate to the sender that you have received this
> communication in error, and delete the copy you received. DigitalGlobe reserves the
> right to monitor any electronic communication sent or received by its employees, agents
> or representatives.
