[gdal-dev] OCI driver and setting the client encoding
Ivan Lucena
ivan.lucena at princeton-ma.us
Thu Sep 20 07:30:09 PDT 2012
Hi Jukka,
> I spent some nice hours trying to get the Finnish characters to appear right in
> Oracle. Now it looks like I have found a working solution but I would like to
> know if it is correct and reliable.
> I am on Windows, Finnins-Finland and chcp shows me code 850. Our Oracle is using
> UTF-8 encoding.
> I tried to transfer data from Spatialite (UTF-8) into Oracle but non-ASCII
> characters were not transferred right. I converted data from Spatialite into GML
> and tried what happens with native UTF-8. Not good so I converted GML into
> ISO-8859-1 with iconv. Bad luck even this way. Then I converted data into
> shapefiles and had some trials with setting the SHAPE_ENCODING environment and
> still the characters were wrong in Oracle side.
> I continued and read a few documents about Oracle NLS_LANG settings and tried to
> set NLS_LANG to correspond with what I thought to suit my console settings. This
> made difference; I got still wrong results but they were different and I started
> to believe that I may be able to win the beast.
> Finally I set environment as
> SET NLS_LANG=american.america.UTF8
> Now I seem to get right characters into Oracle from Spatialite, GML, and
> shapefiles.
So, if I understood it, you are using ogr2ogr in a Finnins-Finland Windows locale but Oracle is set for american.america and the OGR/OCI driver doesn't make the distinction automatically.
Does your data has Finnins-Finland characters on it?
> Is this the right thing to do? If yes, will it work also for other locales and
> could it thus be worth mentioning in the OCI documentation
> http://www.gdal.org/ogr/drv_oci.html? Could it even be initialized automatically
> by the OCI driver?
Check that link for more information:
http://www.oracle.com/technetwork/database/globalization/nls-lang-099431.html
Regards,
Ivan
