[gdal-dev] OCI driver and setting the client encoding
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Thu Sep 20 11:06:41 PDT 2012
Ivan Lucena <ivan.lucena <at> princeton-ma.us> writes:
> So, if I understood it, you are using ogr2ogr in a Finnins-Finland
Windows locale but Oracle is set for
> american.america and the OGR/OCI driver doesn't make the distinction
automatically.
Not really, our Oracle is set to Finnish-Finland and UTF-8
> Does your data has Finnins-Finland characters on it?
The primary data source is Spatialite which is using UTF-8 internally.
Thus I would say that my data does not has Finnish characters, it has
UTF-8 characters, but without setting NLS_LANG the OGR OCI driver does
not consider them as UTF-8 but something else. I suppose that a more
correct NLS_LANG setting for my input data would be
finnish_finland.UTF8. I tested with that and the result was correct,
too. I am not sure what hhappens with shapefiles; the dbf file has
ISO-8859-1 encoding on my computer but it looks like ogr2ogr with
OCI driver is changing the encoding on-the-fly to something else,
perhaps to UTF-8.
I volunteer to test anything that a non-programmer can test for
getting an understanding about how the OCI driver is handling different
character encodings and help in documenting the behaviour.
-Jukka Rahkonen-
> > Is this the right thing to do? If yes, will it work also for other
locales and
> > could it thus be worth mentioning in the OCI documentation
> > http://www.gdal.org/ogr/drv_oci.html? Could it even be initialized
automatically
> > by the OCI driver?
> Check that link for more information:
> http://www.oracle.com/technetwork/database/globalization/nls-lang-099431.html
Just the page that was leading me to right direction.
> Regards,
> Ivan
