[gdal-dev] GDAL / Java bindings : undefined symbol: _ZTVN10__cxxabiv120__si_class_type_infoE in libgdal.so.1
Hendy Sumanto
hsumanto at vpac.org
Fri Sep 21 02:53:08 PDT 2012
I am building GDAL Java Bindings on Centos 6.2 using Oracle Java SDK 1.7
$ cd local/gdal-trunk/gdal
$ ./configure --prefix=/home/579/hxs579/local/gdal-trunk --enable-netcdf4
$ make
$ sudo make install
Then edit the file swig/java/java.opt (from your GDAL source directory)
JAVA_HOME=/usr/java/latest
$ cd swig/java
$ make
But when trying to execute the gdalinfo class as per instruction on trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
I am facing undefined symbol: _ZTVN10__cxxabiv120__si_class_type_infoE in libgdal.so.1
Any idea how to deal with this issue would be really appreciated.
$ java -version
java version "1.7.0_05"
Java(TM) SE Runtime Environment (build 1.7.0_05-b05)
Java HotSpot(TM) 64-Bit Server VM (build 23.1-b03, mixed mode)
Please find below full traces of my errors:
$ javac apps/gdalinfo.java
Note: apps/gdalinfo.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/579/hxs579/local/gdal-trunk/gdal/swig/java
$ java -classpath '/home/579/hxs579/local/gdal-trunk/gdal/swig/java/gdal.jar':/home/579/hxs579/local/gdal-trunk/gdal/swig/java/apps gdalinfo
Native library load failed.
java.lang.UnsatisfiedLinkError: /home/579/hxs579/local/gdal-trunk/gdal/swig/java/libgdaljni.so: /home/579/hxs579/apps/gdal-trunk/lib/libgdal.so.1: undefined symbol: _ZTVN10__cxxabiv120__si_class_type_infoE
Exception in thread "main" java.lang.UnsatisfiedLinkError: org.gdal.gdal.gdalJNI.AllRegister()V
at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
at org.gdal.gdal.gdal.AllRegister(gdal.java:479)
at gdalinfo.main(gdalinfo.java:87)
I never experience this issue before when building GDAL Java Bindings on latest Ubuntu from gdal-trunk SVN checkout.
Cheers,
Hendy
