[gdal-dev] GDAL / Java bindings : undefined symbol: _ZTVN10__cxxabiv120__si_class_type_infoE in libgdal.so.1
Even Rouault
even.rouault at mines-paris.org
Fri Sep 21 04:23:44 PDT 2012
Seeing
> java.lang.UnsatisfiedLinkError:
> /home/579/hxs579/local/gdal-trunk/gdal/swig/java/libgdaljni.so:
> /home/579/hxs579/apps/gdal-trunk/lib/libgdal.so.1: undefined symbol:
You need to add /home/579/hxs579/apps/gdal-trunk/lib in your LD_LIBRARY_PATH too
(in addition to the existing values in it).
Reading http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix , I
see it wasn't mentionned.
