[gdal-dev] Writing a GML file containing multiple layers
Matt Langley mlangley at geoplex.com.au
Wed Apr 3 04:32:13 PDT 2013
Thanks Even,
The 10 char limit on fields names with shapefiles is a problem in my case.
So I will try the VRT format as you have suggested.
Are shapefile and VRT the only formats that can be represented as a multi
layer datasource?
Again - thanks for your help.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Writing-a-GML-file-containing-multiple-layers-tp5044264p5044268.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
