[gdal-dev] 1.9.2 csharp and python interfaces
Finegan Thomas-QTF001
t.finegan at motorolasolutions.com
Wed Apr 3 10:25:04 PDT 2013
Hello,
On Windows, none of the swig interfaces are built with the default target. I have to "cd swig" then run nmake from there. Is there a reason the C# and other wrappers are not built by default?
On Windows, when I run nmake from the swig directory I get:
osr\OsrPINVOKE.cs(192,10): error CS0111: Type 'OSGeo.OSR.OsrPINVOKE' already
defines a member called 'OsrPINVOKE' with the same parameter types
osr\OsrPINVOKE.cs(188,10): (Location of symbol related to previous error)
Please help me fix the problem with OsrPINVOKE being defined twice.
Thank you,
Tom
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130403/a6554b5b/attachment.html>
