[gdal-dev] create only line shapefile
maning sambale
emmanuel.sambale at gmail.com
Thu Apr 25 03:59:28 PDT 2013
I have this syntax:
ogr2ogr -f "ESRI Shapefile" test_osm.shp philippines.osm.pbf -lco SHPT=ARC \
-skipfailures -progress --config OSM_CONFIG_FILE osmconf.ini \
-select name,highway,oneway,maxspeed,access,lanes \
-where "highway is not null" -clipsrc ph_province.shp \
-clipsrcsql "SELECT * FROM ph_province WHERE provname='metro_manila'"
I basically want to extract just the highways in the metro_manila polygon.
But I still get 4 shapefiles (point, line, multilinestrings,
multipolygons, other_relations).
Except for the line.shp, all the other shapefiles are empty.
I defined -lco SHPT=ARC.
How do I just get the lines.shp?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
