[gdal-dev] MODIS Cloud Mask reprojection
Stefan Keller
sfkeller at gmail.com
Sat Apr 27 17:30:34 PDT 2013
Hi Rutger
Many thanks for your answer.
I would like to do the processing of this nice NASA product entirely in
GDAL and Python.
Do you als have hints (code snippets) to achieve this?
Yours,
Stefan
2013/4/26 Rutger <kassies at gmail.com>
> Hey Stefan,
> You indeed need to use MRT Swath (or one of the alternatives i mentioned to
> Laura, but i would start with MRT Swath), which also means you need the
> appropriate MOD03 file for the geolocation arrays. Looking at the meta data
> is should be this one:
> MOD03.A2013112.1055.005.2013112115237.NRT.hdf
> The information is encoded using bitflags. So some post processing is
> needed
> after extracting the bands. A lot of Remote Sensing software can do such
> 'bitwise' operations, but any programming language as well, so reading the
> data with GDAL in for example Python would also work.
> Regards,
> Rutger
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-MODIS-Cloud-Mask-reprojection-tp5049452p5049805.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130428/0883dba1/attachment.html>
