[gdal-dev] MODIS Cloud Mask reprojection
Rutger
kassies at gmail.com
Thu Apr 25 23:38:30 PDT 2013
Hey Stefan,
You indeed need to use MRT Swath (or one of the alternatives i mentioned to
Laura, but i would start with MRT Swath), which also means you need the
appropriate MOD03 file for the geolocation arrays. Looking at the meta data
is should be this one:
MOD03.A2013112.1055.005.2013112115237.NRT.hdf
The information is encoded using bitflags. So some post processing is needed
after extracting the bands. A lot of Remote Sensing software can do such
'bitwise' operations, but any programming language as well, so reading the
data with GDAL in for example Python would also work.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-MODIS-Cloud-Mask-reprojection-tp5049452p5049805.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
