[gdal-dev] FileGDB Driver coordinate system support
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Wed Aug 7 15:15:12 PDT 2013
The ESRI FileGDB api only supports certain projections, BC Albers (epsg:3005) is evidently not one of them. Its in ESRI API issue.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
From: Hailey Eckstrand <haileyeckstrand at gmail.com<mailto:haileyeckstrand at gmail.com>>
Date: Wednesday, August 7, 2013 6:09 PM
To: "gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>" <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Subject: [gdal-dev] FileGDB Driver coordinate system support
Resent-From: Michael Smith <michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>>
Hello,
I am trying to import a feature class from a file geodatabase (version 10 or greater) into PostGIS. After installing the FileGDB driver, I was able to successfully import a feature class which was in the EPSG 4326 spatial reference system.
ogr2ogr -f PostgreSQL PG:dbname=fgdb_test dir4326/test4326.gdb
However, I created another file geodatabase and reprojected the feature class to the BC Albers projection (EPSG: 3005) and then attempted to import the new fgdb again and it failed with no error. My attempts:
ogr2ogr -f PostgreSQL PG:dbname=fgdb_test dir3005/test3005.gdb
ogr2ogr -f PostgreSQL -s_srs EPSG:3005 PG:dbname=fgdb_test dir3005/test3005.gdb
ogr2ogr -f PostgreSQL -t_srs EPSG:3005 PG:dbname=fgdb_test dir3005/test3005.gdb
All failed with no errors. I am not trying to transform while importing.. I would just like to import a feature class in a projected coordinate system.
I am testing using Ubuntu 12.04
GDAL 1.9.2
FileGDB_API_1_3-64
Also, here is the output from ogrinfo:
$ogrinfo dir4326/test4326.gdb/
INFO: Open of `dir4326/test4326.gdb/'
using driver `FileGDB' successful.
1: upcheak_landapp4326 (3D Multi Polygon)
$ogrinfo -al dir3005/test3005.gdb/
INFO: Open of `dir3005/test3005.gdb/'
Thank you,
Hailey
Links to the 2 zip files of my 2 test geodatabases:
http://filebin.ca/qjmBMOaH0cR/dir4326.zip
http://filebin.ca/qjmPiqEAsJ6/dir3005.zip
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130807/87e094fc/attachment.html>
