[gdal-dev] gdal 1.10.0 1.9.2 segmentation faults for WCS requests
Ulrich Leopold
Ulrich.Leopold at Tudor.lu
Thu Aug 8 08:38:31 PDT 2013
Hi Joni,
thanks very much.
The question would be which ones need to be installed. Could you send
your list of packages installed? Maybe then I could compare.
Cheers, Ulrich
On 08/08/13 17:31, Joni-Pekka Kurronen wrote:
> hi,
> i had similar problems, those was from due depencyes can mix older and
> newer
> libraryes needed and both might be / must be installed,...
> joni
> 2013/8/8 Ulrich Leopold <Ulrich.Leopold at tudor.lu
> <mailto:Ulrich.Leopold at tudor.lu>>
> Dear list,
> when using gdal version 1.10.0 and 1.9.2 on ubuntu 12.04 and
> ubuntu 13.04 we get a segmentation fault for any WCS requests (see
> below for an example). Using wget the request works and we can
> save the image. gdalinfo on the saved image works correctly, just
> not on the request directly.
> Any idea why the segmentation fault when using the WCS request
> directly?
> Best, Ulrich
> uleopold at CRTE-ULE-14896:~$ gdb --args gdalinfo
> "http://services.iguess.tudor.lu/cgi-bin/mapserv?map=/srv/mapserv/MapFiles/RO_localOWS_test.map&SERVICE=WCS&FORMAT=image/img&CRS=EPSG:28992&BBOX=91979.0,436326.0,92617.0,437659.5&RESX=0.5&RESY=0.5&VERSION=1.0.0&REQUEST=getCoverage&coverage=ro_dsm_mini"
> GNU gdb (GDB) 7.5.91.20130417-cvs-ubuntu
> Copyright (C) 2013 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later
> <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law. Type "show
> copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu".
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>...
> Reading symbols from /usr/bin/gdalinfo...(no debugging symbols
> found)...done.
> (gdb) r
> Starting program: /usr/bin/gdalinfo
> http://services.iguess.tudor.lu/cgi-bin/mapserv\?map=/srv/mapserv/MapFiles/RO_localOWS_test.map\&SERVICE=WCS\&FORMAT=image/img\&CRS=EPSG:28992\&BBOX=91979.0,436326.0,92617.0,437659.5\&RESX=0.5\&RESY=0.5\&VERSION=1.0.0\&REQUEST=getCoverage\&coverage=ro_dsm_mini
> <http://services.iguess.tudor.lu/cgi-bin/mapserv%5C?map=/srv/mapserv/MapFiles/RO_localOWS_test.map%5C&SERVICE=WCS%5C&FORMAT=image/img%5C&CRS=EPSG:28992%5C&BBOX=91979.0,436326.0,92617.0,437659.5%5C&RESX=0.5%5C&RESY=0.5%5C&VERSION=1.0.0%5C&REQUEST=getCoverage%5C&coverage=ro_dsm_mini>
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library
> "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff27d4cd1 in ?? () from
> /usr/lib/x86_64-linux-gnu/libdapclient.so.3
> (gdb) bt
> #0 0x00007ffff27d4cd1 in ?? () from
> #1 0x00007ffff27e37b3 in std::vector<std::string,
> std::allocator<std::string> >::~vector() () from
> #2 0x00007ffff27e0bbf in
> libdap::HTTPConnect::plain_fetch_url(std::string const&) () from
> #3 0x00007ffff27e16c0 in
> libdap::HTTPConnect::fetch_url(std::string const&) () from
> #4 0x00007ffff27da48b in libdap::Connect::request_version() ()
> from /usr/lib/x86_64-linux-gnu/libdapclient.so.3
> #5 0x00007ffff732dfc5 in ?? () from /usr/lib/libgdal.so.1
> #6 0x00007ffff7333da9 in ?? () from /usr/lib/libgdal.so.1
> #7 0x00007ffff75789e9 in ?? () from /usr/lib/libgdal.so.1
> #8 0x00007ffff7578c46 in ?? () from /usr/lib/libgdal.so.1
> #9 0x0000000000402c8f in ?? ()
> #10 0x00007ffff65dfea5 in __libc_start_main () from
> /lib/x86_64-linux-gnu/libc.so.6
> #11 0x00000000004044f5 in ?? ()
> Ulrich Leopold
> Senior Researcher in Geocomputation
> Resource Centre for Environmental Technologies
> Public Research Centre Henri Tudor
> 6A, avenue des Hauts-Fourneaux
> L-4362 Esch-sur-Alzette
> Luxembourg
> tel: +352 425991 4618 <tel:%2B352%20425991%204618>
> fax: +352 425991 555 <tel:%2B352%20425991%20555>
> mobile: +352 691 304813 <tel:%2B352%20691%20304813>
> email: ulrich.leopold at tudor.lu <mailto:ulrich.leopold at tudor.lu>
> http://www.tudor.lu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Joni-Pekka Kurronen
> Joni.Kurronen at gmail.com <mailto:Joni.Kurronen at gmail.com>
> gsm. +358 50 521 2279
Ulrich Leopold
Luxembourg
http://www.tudor.lu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130808/8b5c7ba8/attachment-0001.html>
