[gdal-dev] Upgrade Python GDAL package in pypi
Even Rouault
even.rouault at mines-paris.org
Sun Aug 11 13:55:43 PDT 2013
Le dimanche 11 août 2013 22:33:34, Howard Butler a écrit :
> On Aug 6, 2013, at 10:57 AM, Ricardo Filipe Soares Garcia da
<ricardo.garcia.silva at gmail.com> wrote:
> > Hello list
> > I have been using GDAL Python bindings inside a virtualenv on some
> > ubuntu-server 12.04 machines to do geoprocessing tasks.
> > I have an automated script to setup GDAL from the ubuntugis repository
> > and then use pip to get the Python bindings code (from pypi) and execute
> > setup.py with the correct gdal paths and compile the bindings. It used
> > to work nicely.
> > Unfortunately, now that GDAL 1.10 is out and the ubuntugis folks have
> > upgraded their GDAL, I cannot do this anymore, because the pypi version
> > of GDAL is still at 1.9.1.
> > I'd like to kindly request that the package available in the python
> > package index be upgraded to version 1.10 too.
> > Thanks
> Ricardo,
> I have updated the PyPI package to 1.10. We should probably make this part
> of our regular packaging tasks, as it is very much a one-off thing that I
> do manually for releases at this time. If Even or any of the other GDAL
> devs have PyPI logins, please let me know, and I'll add you to the
> maintainer list so you can push new releases.
Howard,
I'm not familiar with the process to update stuff in PyPi. Could this be
documented in HOWTO-RELEASE ?
My PyPi login is Even.Rouault
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
