[gdal-dev] QGIS hanging when opening a FileGDB on 64 bit Linux
Jeremy Palmer
JPalmer at linz.govt.nz
Mon Aug 12 17:01:24 PDT 2013
Wow Even - just amazing as always.
Have you confirmed that you can no open a FileGDB in QGIS? I still get the freeze when using GDAL trunk, but maybe that now a QGIS problem.
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Tuesday, 13 August 2013 11:29 a.m.
To: gdal-dev at lists.osgeo.org
Cc: Jeremy Palmer; 'qgis-developer at lists.osgeo.org'
Subject: Re: [gdal-dev] QGIS hanging when opening a FileGDB on 64 bit Linux
Le lundi 12 août 2013 22:12:11, Jeremy Palmer a écrit :
> Further to this I see that when you open a FIleGDB in QGIS 3 OGROpen
> calls made to the same database before any OGR_DS_Destroy calls are
> made. These open calls occur during the layer selection dialog, the
> OGR provider construction, and the initialisation of the QgsOgrFeatureIterator.
> I'm guessing the fix for this should really be done at the Esri
> library level, but because we have no control over this maybe
> something can be done in the OGR library to reuse FileGDBAPI Geodatabase handles?
Jeremy,
I do think this is exactly the issue of http://forums.arcgis.com/threads/76527-CloseDatabase-hanging-on-64-bit-Lin ux- when-same-File-Geodatabase-opened-twice
At least I reproduced it on my own PC. I've implemented a workaround in GDAL trunk for that issue that implements ref-counting of the FileGDBAPI Geodabase handle at OGR side : http://trac.osgeo.org/gdal/changeset/26307.
Even
> Cheers,
> Jeremy
> From: Jeremy Palmer
> Sent: Sunday, 11 August 2013 9:08 a.m.
> To: qgis-developer at lists.osgeo.org
> Subject: QGIS hanging when opening a FileGDB on 64 bit Linux
> Hi QGIS devs!
> Since the latest round of code changes (maybe over the last 2 months)
> I can no longer open Esri FileGDB in QGIS. I can read the database and
> QGIS prompts me from the FileGDB layers to add to the map, but when I
> select the layer from this dialog QGIS just hangs. I did some
> debugging and it seems to hang on the OGR_DS_Destroy call within
> QgsOgrFeatureIterator::close(). Does anyone else have this problem?
> I'm running FileGDB SDK 1.3 and Ubuntu 12.04 64bit with QGIS master.
> I've tested this with the OSGeo4W win32 qgis-dev package and I don't
> get the problem.
> Could this be related to this issue:
> -Lin ux-when-same-File-Geodatabase-opened-twice
> Cheers,
> Jeremy
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you
> must not peruse, use, disseminate, distribute or copy this message. If
> you have received this message in error, please notify us immediately
> (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> gdal-dev mailing list
Geospatial professional services
http://even.rouault.free.fr/services.html
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
