[gdal-dev] Passing RAT between drivers, including VRT
Even Rouault even.rouault at mines-paris.org
Thu Aug 15 11:45:59 PDT 2013
Le jeudi 15 août 2013 20:04:51, Ivan Lucena a écrit :
> Hi Even,
> I double checked and I noticed that this is not true:
> > > The RAT is transferred to the geotiff file in both instances.
> I pass -a_nodata and got no RAT as you can see on the
> following log.
> Without -a_nodata the file gtiff_i8u_c_i.tif.aux.xml is create with the
> full RAT.
Yes, that's exactly what I said in my previous email.
> But for output HFA that is still true. I can pass
>  -a_nodata or not and the RAT is always copied to the output.
> Try that:
> $ gdal_translate -of hfa i8u_c_i.img hfa_i8u_c_i.img -a_nodata 0
> Is that the same that you are getting over there?
Well, this is different. The HFA driver is a bit particular in its behaviour
and reports a RAT when there's a color table (in fact a color table is a
particular type of RAT). So technically the RAT of the source IMG is not
transferred into the target IMG in the -a_nodata 0 case, but the color table
is.
Geospatial professional services
http://even.rouault.free.fr/services.html
