[gdal-dev] Problem with gdal/swig/plugins
jim hopper
JAMES.E.HOPPER at saic.com
Fri Aug 16 11:33:57 PDT 2013
Is there any limitations on which version of swig can be used with gdal. We
are running into problems where our java code can¹t find the gdal plugins.
15:35:27,055 WARNING [it.geosolutions.imageio.gdalframework]
(http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: DTED
Cause: java.lang.UnsatisfiedLinkError:
org.gdal.gdal.gdalJNI.SWIGDriverUpcast(J)J
This is not a problem unless you need to use the specified GDAL plugin. It
won't be enabled
15:35:27,076 WARNING [it.geosolutions.imageio.gdalframework]
(http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: JP2KAK
won't be enabled
