[gdal-dev] Problem with gdal/swig/plugins
Even Rouault even.rouault at mines-paris.org
Fri Aug 16 11:58:50 PDT 2013
Le vendredi 16 août 2013 20:33:57, jim hopper a écrit :
> Is there any limitations on which version of swig can be used with gdal.
> We are running into problems where our java code can¹t find the gdal
> plugins.
When you ask a question about versions, it is good to say which version you
are using...
They work fine with swig 1.3.40 and swig 2.0.8
Which one are you trying ?
> 15:35:27,055 WARNING [it.geosolutions.imageio.gdalframework]
> (http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: DTED
> Cause: java.lang.UnsatisfiedLinkError:
> org.gdal.gdal.gdalJNI.SWIGDriverUpcast(J)J
> This is not a problem unless you need to use the specified GDAL plugin. It
> won't be enabled
> 15:35:27,076 WARNING [it.geosolutions.imageio.gdalframework]
> (http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: JP2KAK
> won't be enabled
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
