[gdal-dev] Motion: Approve GDAL/OGR 1.10.1RC1 for release
Kurt Schwehr
schwehr at gmail.com
Sat Aug 24 17:34:21 PDT 2013
Since I haven't check on any prior update, I consider this just a baseline and don't see this as a reason to hold up the update.
Notes inline. backing off on png gave a passing test. backing off on jpeg... no change.
Other issues, I'll see if I can look into later.
-kurt
On Aug 24, 2013, at 11:26 AM, Even Rouault <even.rouault at mines-paris.org> wrote:
> Le samedi 24 août 2013 19:57:47, Kurt Schwehr a écrit :
>> LGTM with respect to fink package on mac osx 10.8
>> - Looks like I have a todo on jasper.
>> - not sure on http_4
>> - png.py and test_gdalwarp below.
>> - rest are flagged as know issues or pre-release things
> Hi Kurt,
> Thanks for your testing. Comments below
>> -kurt
>> ------------ Failures ------------
>> Script: ogr/ogr_shape.py
>> TEST: ogr_shape_68 ... fail
>> line 3249: fail
> Yes, I observed that it fails on Travis too on the Mac. Not sure why being not
> in a position to debug on the Mac. Advanced stuff, not critical if it doesn't
> work
>> Script: gcore/basic_test.py
>> TEST: basic_test_8 ... fail
> Same, fails on Travis for unknown reason on the Mac. The test is likely a bit
> fragile.
>> line 161: fail
>> Script: gcore/gdal_api_proxy.py
>> TEST: gdal_api_proxy_3 ... fail
> Same, fails on Travis for unknown reason on the Mac. Advanced stuff, not
> critical if it doesn't work
>> Script: gdrivers/gdalhttp.py
>> TEST: http_4 ... fail
> Might be linked to a temporary unavailability of the remote resource. I
> somehow remember that it can fail sometimes, but I have never tested on the
> Mac, so it might not be just an interminent failure
> Does "gdalinfo
> /vsicurl/ftp://ftp2.cits.rncan.gc.ca/pub/cantopo/250k_tif/MCR2010_01.tif"
> repeatedly fail ?
> You can try adding "--debug CPL_CURL_VERBOSE YES" for more info.
I think you called it with just being a network issue
./gdalhttp.py
TEST: http_1 ... success
TEST: http_2 ... success
TEST: http_3 ... success
TEST: http_4 ... success
TEST: http_cleanup ... success
Test Script: http
Succeeded: 5
Failed: 0 (0 blew exceptions)
Skipped: 0
Expected fail:0
Duration: 11.35s
>> Script: gdrivers/jpeg2000.py
>> TEST: jpeg2000_8 ... fail
>> line 189: Jasper library would need patches
> Yes, this is a defect in upstream jasper that most linux distro have patched.
> Applying Debian patches might help you fix that
>> Script: gdrivers/png.py
>> TEST: png_1 ... fail
>> line 429: Checksum for band 1 in "test.png" is 6846, but expected
>> 57921. TEST: png_2 ... fail
>> line 484: Failed to create test file using CreateCopy method.
>> libpng: No IDATs written into file
> Hum, this is new to me. Which libpng version do you use ?
otool -L /sw/bin/gdalinfo | grep png
/sw/lib/libpng16.16.dylib (compatibility version 20.0.0, current version 20.0.0)
libpng16 1.6.3-1
backing off to libpng15 1.5.17-1 gives success:
/sw/lib/libpng15.15.dylib (compatibility version 33.0.0, current version 33.0.0)
./png.py
TEST: png_1 ... success
TEST: png_2 ... success
TEST: png_3 ... success
TEST: png_4 ... success
TEST: png_5 ... success
TEST: png_6 ... success
TEST: png_7 ... success
TEST: png_8 ... success
TEST: png_9 ... success
TEST: png_10 ... success
TEST: png_11 ... success
Test Script: png
Succeeded: 11
Skipped: 0
Expected fail:0
Duration: 0.05s
>> Script: utilities/test_gdalwarp.py
>> TEST: test_gdalwarp_33 ... fail
> The test might be a bit fragile indeed. It might depend on the libjpeg version
> you are using. There's a tolerance at 37, and you have reached 40. Could
> likely be changed to 40.
otool -L /sw/bin/gdalinfo | grep jp
/sw/lib/libjpeg.9.dylib (compatibility version 10.0.0, current version 10.0.0)
i libjpeg9-shlibs 9-3 Shared libraries for libjpeg package
Backing off still has a test that fails
/sw/lib/libjpeg.8.dylib (compatibility version 13.0.0, current version 13.0.0)
i libjpeg8-shlibs 8d-3
TEST: test_gdalwarp_33 ... Diff at pixel (160, 0) : 7.000000
Diff at pixel (161, 0) : 1.000000
Diff at pixel (162, 0) : 6.000000
Diff at pixel (165, 0) : 2.000000
Diff at pixel (167, 0) : 8.000000
Diff at pixel (169, 0) : 8.000000
Diff at pixel (173, 0) : 4.000000
Diff at pixel (174, 0) : 9.000000
Diff at pixel (176, 0) : 9.000000
Diff at pixel (189, 0) : 10.000000
Diff at pixel (266, 0) : 13.000000
Diff at pixel (284, 0) : 17.000000
Diff at pixel (172, 1) : 22.000000
Diff at pixel (265, 1) : 31.000000
Diff at pixel (301, 6) : 32.000000
Diff at pixel (388, 37) : 38.000000
Diff at pixel (118, 319) : 40.000000
Max diff : 40
Number of diffs : 3683
fail
TEST: test_gdalwarp_34 ... success
TEST: test_gdalwarp_35 ... success
TEST: test_gdalwarp_36 ... success
TEST: test_gdalwarp_cleanup ... success
Test Script: test_gdalwarp
Succeeded: 37
Failed: 1 (0 blew exceptions)
Skipped: 0
Expected fail:0
Duration: 1.80s
>> Succeeded: 2608
>> Failed: 8 (0 blew exceptions)
>> Skipped: 723
>> Expected fail:12
>> Duration: 06m4.3s
>> As GDAL_DOWNLOAD_TEST_DATA environment variable is not defined, 107 tests
>> relying on data to downloaded from the Web have been skipped As
>> GDAL_RUN_SLOW_TESTS environment variable is not defined, 22 "slow" tests
>> have been skipped
>> png.py:
>> python png.py
>> TEST: png_1 ... ERROR 1: libpng: IDAT: invalid distance too far back
>> ERROR 1: data/test.png, band 1: IReadBlock failed at X offset 0, Y offset
>> 29 ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 29
>> ERROR 3: Checksum value couldn't be computed due to I/O read error.
>> fail
>> 57921. TEST: png_2 ... ERROR 1: libpng: IDAT: invalid distance too far
>> back ERROR 1: data/test.png, band 1: IReadBlock failed at X offset 0, Y
>> offset 29 ERROR 1: libpng: IDAT: invalid distance too far back
>> 30 ERROR 1: libpng: IDAT: invalid distance too far back
>> TEST: test_gdalwarp_32 ... success
>> Max diff : 40
>> fail
>> On Aug 23, 2013, at 11:27 AM, Even Rouault <even.rouault at mines-paris.org>
> wrote:
>>> Hi,
>>> PSC members, please vote for the following motion after conducting your
>>> own testing.
>>> Non-PSC members please let us know if you discover problems.
>>> Motion: The GDAL/OGR 1.10.1RC1 package is promoted as the
>>> final GDAL/OGR 1.10.1 release.
>>> +1 Even
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Geospatial professional services
> http://even.rouault.free.fr/services.html
