[gdal-dev] Motion: Approve GDAL/OGR 1.10.1RC1 for release
Even Rouault
even.rouault at mines-paris.org
Sun Aug 25 02:59:19 PDT 2013
Le dimanche 25 août 2013 02:34:21, Kurt Schwehr a écrit :
> Since I haven't check on any prior update, I consider this just a baseline
> and don't see this as a reason to hold up the update.
Yes, that doesn't look criticial to me either, apart the failures with libpng
1.6.3
> Notes inline. backing off on png gave a passing test. backing off on
> jpeg... no change. Other issues, I'll see if I can look into later.
I've tested against libpng 1.6.3 on Linux 64bit, and I don't get any failed
tests on png.py. Strange. Do the png utilities of libpng 1.6.3 work on
autotest/gdrivers/data/test.png ?
I've also tested libjpeg-9a and could reproduce the failure on gdalwarp_33.
Visual inspectiong of the result looks OK, so that's just a difference in the
maths involved in JPEG decompression between libjpeg versions. I'll increase
the tolerance to 40.
> -kurt
> On Aug 24, 2013, at 11:26 AM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> > Le samedi 24 août 2013 19:57:47, Kurt Schwehr a écrit :
> >> LGTM with respect to fink package on mac osx 10.8
> >> - Looks like I have a todo on jasper.
> >> - not sure on http_4
> >> - png.py and test_gdalwarp below.
> >> - rest are flagged as know issues or pre-release things
> > Hi Kurt,
> > Thanks for your testing. Comments below
> >> -kurt
> >> ------------ Failures ------------
> >> Script: ogr/ogr_shape.py
> >> TEST: ogr_shape_68 ... fail
> >> line 3249: fail
> > Yes, I observed that it fails on Travis too on the Mac. Not sure why
> > being not in a position to debug on the Mac. Advanced stuff, not
> > critical if it doesn't work
> >> Script: gcore/basic_test.py
> >> TEST: basic_test_8 ... fail
> > Same, fails on Travis for unknown reason on the Mac. The test is likely a
> > bit fragile.
> >> line 161: fail
> >> Script: gcore/gdal_api_proxy.py
> >> TEST: gdal_api_proxy_3 ... fail
> > Same, fails on Travis for unknown reason on the Mac. Advanced stuff, not
> >> Script: gdrivers/gdalhttp.py
> >> TEST: http_4 ... fail
> > Might be linked to a temporary unavailability of the remote resource. I
> > somehow remember that it can fail sometimes, but I have never tested on
> > the Mac, so it might not be just an interminent failure
> > Does "gdalinfo
> > /vsicurl/ftp://ftp2.cits.rncan.gc.ca/pub/cantopo/250k_tif/MCR2010_01.tif"
> > repeatedly fail ?
> > You can try adding "--debug CPL_CURL_VERBOSE YES" for more info.
> I think you called it with just being a network issue
> ./gdalhttp.py
> TEST: http_1 ... success
> TEST: http_2 ... success
> TEST: http_3 ... success
> TEST: http_4 ... success
> TEST: http_cleanup ... success
> Test Script: http
> Succeeded: 5
> Failed: 0 (0 blew exceptions)
> Skipped: 0
> Expected fail:0
> Duration: 11.35s
> >> Script: gdrivers/jpeg2000.py
> >> TEST: jpeg2000_8 ... fail
> >> line 189: Jasper library would need patches
> > Yes, this is a defect in upstream jasper that most linux distro have
> > patched. Applying Debian patches might help you fix that
> >> Script: gdrivers/png.py
> >> TEST: png_1 ... fail
> >> line 429: Checksum for band 1 in "test.png" is 6846, but expected
> >> 57921. TEST: png_2 ... fail
> >> line 484: Failed to create test file using CreateCopy method.
> >> libpng: No IDATs written into file
> > Hum, this is new to me. Which libpng version do you use ?
> otool -L /sw/bin/gdalinfo | grep png
> /sw/lib/libpng16.16.dylib (compatibility version 20.0.0, current version
> 20.0.0)
> libpng16 1.6.3-1
> backing off to libpng15 1.5.17-1 gives success:
> /sw/lib/libpng15.15.dylib (compatibility version 33.0.0, current version
> 33.0.0)
> ./png.py
> TEST: png_1 ... success
> TEST: png_2 ... success
> TEST: png_3 ... success
> TEST: png_4 ... success
> TEST: png_5 ... success
> TEST: png_6 ... success
> TEST: png_7 ... success
> TEST: png_8 ... success
> TEST: png_9 ... success
> TEST: png_10 ... success
> TEST: png_11 ... success
> Test Script: png
> Succeeded: 11
> Skipped: 0
> Expected fail:0
> Duration: 0.05s
> >> Script: utilities/test_gdalwarp.py
> >> TEST: test_gdalwarp_33 ... fail
> > The test might be a bit fragile indeed. It might depend on the libjpeg
> > version you are using. There's a tolerance at 37, and you have reached
> > 40. Could likely be changed to 40.
> otool -L /sw/bin/gdalinfo | grep jp
> /sw/lib/libjpeg.9.dylib (compatibility version 10.0.0, current version
> 10.0.0)
> i libjpeg9-shlibs 9-3 Shared libraries
> for libjpeg package
> Backing off still has a test that fails
> /sw/lib/libjpeg.8.dylib (compatibility version 13.0.0, current version
> 13.0.0)
> i libjpeg8-shlibs 8d-3
> TEST: test_gdalwarp_33 ... Diff at pixel (160, 0) : 7.000000
> Diff at pixel (161, 0) : 1.000000
> Diff at pixel (162, 0) : 6.000000
> Diff at pixel (165, 0) : 2.000000
> Diff at pixel (167, 0) : 8.000000
> Diff at pixel (169, 0) : 8.000000
> Diff at pixel (173, 0) : 4.000000
> Diff at pixel (174, 0) : 9.000000
> Diff at pixel (176, 0) : 9.000000
> Diff at pixel (189, 0) : 10.000000
> Diff at pixel (266, 0) : 13.000000
> Diff at pixel (284, 0) : 17.000000
> Diff at pixel (172, 1) : 22.000000
> Diff at pixel (265, 1) : 31.000000
> Diff at pixel (301, 6) : 32.000000
> Diff at pixel (388, 37) : 38.000000
> Diff at pixel (118, 319) : 40.000000
> Max diff : 40
> Number of diffs : 3683
> fail
> TEST: test_gdalwarp_34 ... success
> TEST: test_gdalwarp_35 ... success
> TEST: test_gdalwarp_36 ... success
> TEST: test_gdalwarp_cleanup ... success
> Test Script: test_gdalwarp
> Succeeded: 37
> Failed: 1 (0 blew exceptions)
> Skipped: 0
> Expected fail:0
> Duration: 1.80s
> >> Succeeded: 2608
> >> Failed: 8 (0 blew exceptions)
> >> Skipped: 723
> >> Expected fail:12
> >> Duration: 06m4.3s
> >> As GDAL_DOWNLOAD_TEST_DATA environment variable is not defined, 107
> >> tests relying on data to downloaded from the Web have been skipped As
> >> GDAL_RUN_SLOW_TESTS environment variable is not defined, 22 "slow"
> >> tests have been skipped
> >> png.py:
> >> python png.py
> >> TEST: png_1 ... ERROR 1: libpng: IDAT: invalid distance too far back
> >> ERROR 1: data/test.png, band 1: IReadBlock failed at X offset 0, Y
> >> offset 29 ERROR 1: GetBlockRef failed at X block offset 0, Y block
> >> offset 29 ERROR 3: Checksum value couldn't be computed due to I/O read
> >> error.
> >> fail
> >> 57921. TEST: png_2 ... ERROR 1: libpng: IDAT: invalid distance too far
> >> back ERROR 1: data/test.png, band 1: IReadBlock failed at X offset 0, Y
> >> offset 29 ERROR 1: libpng: IDAT: invalid distance too far back
> >> offset 30 ERROR 1: libpng: IDAT: invalid distance too far back
> >> TEST: test_gdalwarp_32 ... success
> >> Max diff : 40
> >> fail
> >> On Aug 23, 2013, at 11:27 AM, Even Rouault
> > wrote:
> >>> Hi,
> >>> PSC members, please vote for the following motion after conducting your
> >>> own testing.
> >>> Non-PSC members please let us know if you discover problems.
> >>> Motion: The GDAL/OGR 1.10.1RC1 package is promoted as the
> >>> final GDAL/OGR 1.10.1 release.
> >>> +1 Even
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Geospatial professional services
http://even.rouault.free.fr/services.html
