[gdal-dev] gdalwarp -tps
Andre Joost
andre+joost at nurfuerspam.de
Thu Aug 29 07:17:19 PDT 2013
Am 29.08.2013 11:27, schrieb laura0:
> Hi all,
> I would like to know how to use thin plate spline interpolation with gdal.
> I have found the gdalwarp -tps option but I do not understand how to use it,
> I have a UTM 32 reprojected geotiff and I find here
> http://www.gdal.org/gdalwarp.html
> ERROR 4: `265331.439' does not exist in the file system,
> and is not recognised as a supported dataset name
Adding the GCP at the command line is not supported.
> Can someone explain me how this option works?
Have a look at this old posting:
http://lists.osgeo.org/pipermail/gdal-dev/2006-July/009676.html
HTH,
André Joost
