[gdal-dev] Force application of ntv2 grid
stevejking stevejking at talktalk.net
Tue Dec 10 06:02:49 PST 2013
Andre Joost wrote
> Am 29.11.2013 09:59, schrieb Jeremy Palmer:
>> Hi gdal-devs,
>> I'm trying to shift shapefile data using a custom NTv2 grid file. The
>> logical source and destination coordinate systems are the same
>> (geographic coordinates EPSG:4167), I only want to shift the data.
>> The type of command I'm trying to run is:
>> ogr2ogr -f "Esri Shapefile" -a_srs "+proj=longlat +ellps=GRS80"
>> -t_srs "+proj=longlat +ellps=GRS80 +nadgrids=custom_grid.gsb +wktext"
>> dst_datasource_name src_datasource_name
>> but the output shapefile does not get transformed...
>> Is this because there is a short circuit in proj4 if the ellipsoids
>> are the same?
> No, you have to explicitely specify +towgs84=0,0,0,0,0,0,0 for the first
> srs. Otherwise it is assumed that both share the same datum.
> HTH,
> André Joost
> gdal-dev mailing list
> gdal-dev at .osgeo
Andre is on the right track.
But, I believe you need to specify the +nadgrids=c:\custom_grid.gsb in your
source projection, then use the +towgs84=0,0,0,0,0,0,0 in your target.
You may get away without specifying any path to your gsb, not sure.
HTH
Regards,
Steve
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Force-application-of-ntv2-grid-tp5091818p5093536.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
