[gdal-dev] Force application of ntv2 grid
Thomas Campagne
thomas.campagne at gmail.com
Tue Dec 10 08:47:15 PST 2013
2013/12/10 stevejking <stevejking at talktalk.net>
> Andre Joost wrote
> > Am 29.11.2013 09:59, schrieb Jeremy Palmer:
> >> Hi gdal-devs,
> >> I'm trying to shift shapefile data using a custom NTv2 grid file. The
> >> logical source and destination coordinate systems are the same
> >> (geographic coordinates EPSG:4167), I only want to shift the data.
> >> The type of command I'm trying to run is:
> >> ogr2ogr -f "Esri Shapefile" -a_srs "+proj=longlat +ellps=GRS80"
> >> -t_srs "+proj=longlat +ellps=GRS80 +nadgrids=custom_grid.gsb +wktext"
> >> dst_datasource_name src_datasource_name
> >> but the output shapefile does not get transformed...
> >> Is this because there is a short circuit in proj4 if the ellipsoids
> >> are the same?
> > No, you have to explicitely specify +towgs84=0,0,0,0,0,0,0 for the first
> > srs. Otherwise it is assumed that both share the same datum.
> > HTH,
> > André Joost
> > gdal-dev mailing list
> > gdal-dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Andre is on the right track.
> But, I believe you need to specify the +nadgrids=c:\custom_grid.gsb in your
> source projection, then use the +towgs84=0,0,0,0,0,0,0 in your target.
> You may get away without specifying any path to your gsb, not sure.
> HTH
> Regards,
> Steve
Just as a side note, I like to turn on the debugging mode by setting the
environment variable PROJ_DEBUG to any number.
It gives useful info on how your ntv2 grid is used and might help you
identify other issues if any.
Regards
Thomas
Thomas Campagne
Vancouver, BC
Canada
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131210/016d705d/attachment.html>
