[gdal-dev] Generating Lat, long Cordinates with bearing line and angle
Even Rouault even.rouault at mines-paris.org
Tue Dec 17 00:41:50 PST 2013
Selon Phil Scadden <p.scadden at gns.cri.nz>:
> > I have a *lat, lon* coordinate with a known projection system I assume
> > it a initial point. I want to generate a next Position with the an
> > *angle* with (horizontal/vertical)  and *bearing length*  in lat,lon
> > coordinates and complete it with angles and bearing lengths to form a
> > polygon
> Try http://www.movable-type.co.uk/scripts/latlong.html#destPoint
> However, you need to be very careful with this as calculations are being
> done assuming a spherical earth. Fine is distances arent large enough
> for the ellipsoidal effects to affect accuracy. For large distances, you
> need to use Vincent' s_formula -
> http://en.wikipedia.org/wiki/Vincenty%27s_formulae which require iteration.
http://geographiclib.sourceforge.net/ has an implementation of it.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
