[gdal-dev] Call for discussion on "RFC 45: GDAL datasets and raster bands as virtual memory mappings"
Even Rouault
even.rouault at mines-paris.org
Tue Dec 17 12:54:31 PST 2013
This is a call for discussion for "RFC 45: GDAL datasets and raster bands as
Beginning of the RFC inline (the full RFC includes a few colorful schemas !) :
== Summary ==
This document proposes additions to GDAL so that image data of GDAL datasets
and
raster bands can be seen as virtual memory mappings, for hopefully simpler
usage.
== Rationale ==
When one wants to read or write image data from/into a GDAL dataset or raster
band, one must use the RasterIO() interface for the regions of interest that
are read or written. For small images, the most convenient solution is usually
to read/write the whole image in a single request where the region of interest
is the full raster extent. For larger images, particularly when they do not
fit entirely in RAM, this is not possible, and if one wants to operate on the
whole image, one must use a windowing strategy to avoid memory issues :
typically
by proceeding scanline (or group of scanlines) by scanline, or by blocks for
tiled
images. This can make the writing of algorithms more complicated when they
need
to access a neighbourhoud of pixels around each pixel of interest, since the
size of this
extra window must be taken into account, leading to overlapping regions of
interests. Nothing that cannot be solved, but that requires some additional
thinking that distracts from the followed main purpose.
The proposed addition of this RFC is to make the image data appear as a single
array accessed with a pointer, without being limited by the size of RAM with
respect to the size of the dataset (excepted limitations imposed by the CPU
architecture and the operating system)
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
