[gdal-dev] ISO WKB
Paul Ramsey pramsey at cleverelephant.ca
Tue Dec 17 21:28:16 PST 2013
I don't think we should expose the ISO geometry types to the world,
they're just for WKB really, so I'll keep that part hidden away. It's
a shame we can't get rid of the 25d type variants for gdal2... if not
then, when?
Incidentally, is there going to be a GDAL 1.11?
P.
On Tue, Dec 17, 2013 at 1:50 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Le mardi 17 décembre 2013 22:38:26, Paul Ramsey a écrit :
>> OK, so hide the ISO types from the outside world. No problem.
>> Is it OK to have getGeometryType and exportToWkb accept wkbVariant
>> optional parameters?
> For exportToWkb(), it is just a matter of taste whether to add an optional
> parameter or to have a dedicated method.
> For getGeometryType(), as it returns a OGRwkbGeometryType, you can't add an
> optional parameter to return values other than OGRwkbGeometryType.
> My latest proposal was to have a - protected - "int
> getGeometryType(wkbVariant)  { return
> (eVariant == wkbVariantOgc) ? getGeometryType()  :
> getIsoGeometryType(); }" and a public OGRwkbIsoGeometryType
> getIsoGeometryType().
>> P.
>> On Tue, Dec 17, 2013 at 1:03 AM, Even Rouault
>> > Selon Paul Ramsey <pramsey at cleverelephant.ca>:
>> >> Back to this, is it OK?
>> > As said in
>> > http://lists.osgeo.org/pipermail/gdal-dev/2013-December/037738.html, I
>> > feel a bit unconfortable with the extension of the OGRwkbGeometryType
>> > enumeration that has possible impacts on other parts of OGR. There's
>> > perhaps a time where we will touch it, but I'd expect it to ideally
>> > embrace Z, M, ZM, circular geometries at once. And that would deserve a
>> > RFC.
>> > What do you think of keeping it an internal enumeration of OGR, since
>> > that's probably all you need for now ?
>> > "Or have a separate OGRwkbIsoGeometryType enumeration { wkbPointIso, ...
>> > wkbGeometryCollectionIso, wkbPointIsoZ, ... wkbGeometryCollectionIsoZ },
>> > a getIsoGeometryType() method that returns it, and the exportToWkb()
>> > methods that calls int getGeometryType(OGRwkbVariant eVariant) { return
>> > (eVariant == wkbVariantOgc) ? getGeometryType()  : getIsoGeometryType();
>> > I'd be happy to hear about other GDAL developers opinion on this.
>> >> How are we patching back to SVN? I can convert
>> >> it into a patch and attach to a ticket, if that's the path.
>> > git-svn can be used to bridge the 2 worlds, but in my recent experience
>> > it has been painful to use. So generating a patch and applying it is
>> > probably easier.
>> > Even
>> > Geospatial professional services
>> > http://even.rouault.free.fr/services.html
