[gdal-dev] Multiple extensions in GDAL_DMD_EXTENSION ?
Tue Feb 19 09:59:47 PST 2013
On Tue, Feb 19, 2013 at 9:39 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> It would be nice to be able to specify many extensions in a
> comma-separated list such as "nc,cdf,nc4". It can probably be done
> (metadata is just a string), but isn't standard.
> The Gdal driver tutorial states:
> GDAL_DMD_EXTENSION: The extension used for files of this type. If more
> than one pick the primary extension, or none at all. (optional)
> It could be beneficial to extend this definition for multiple
> extensions separated by comma.
Etienne,
The challenge is to do this without breaking lots of applications that
expect it to be a single extension.  If we were to pursue this, I'd
almost prefer to add GDAL_DMD_EXTENSION_LIST as a list of extensions
that relate to this driver, and GDAL_DMD_EXTENSION would be the
primary or preferred extension.
But I'm still not all that keen.  I see the GDAL_DMD_EXTENSION as
existing primarily so that applications can prepare a reasonable
default filename when creating a file.  For this having a list of
extensions is not helpful.
People *usually* want a list of extensions so they can automatically
categorize the format of files on disk or to filter to only show
extensions they think GDAL supports.  I find this practice abhorrent!
 GDAL is based on the idea that file formats are discovered by
inspecting file contents rather than based on extension and I don't
want to make it too easy for applications to ignore this principle and
revert to extensions.
One other use that extensions are used for is to make it easy for a
user to filter down files in a file browser to just one format.  I
can't think of any time I've found this useful.  But with GDAL there
are so many formats that these "list of formats" filter dohickyies are
usually completely unusable.
Best regards,
and watch the world go round - Rush    | Geospatial Software Developer
