[gdal-dev] ogr WFS GML parse error with WFS 1.1.0
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Tue Feb 26 14:24:11 PST 2013
Jeremy Palmer <JPalmer <at> linz.govt.nz> writes:
> When use WFS to pull a large GML object it fails:
> ogrinfo -dialect sqlite -sql "select id, shape from \"v:x1571\"
WHERE id = 3241251"
WFS:'http://wfs.data.linz.govt.nz/84f646e35be34843abd9cee6085b50d6/v/x1571/wfs'
> ERROR 1: XML parsing of GML file failed : mismatched tag at line 2,
column 3621825
I can reproduce, but the mismatched tag is reported to be in another
column (3621905) for me. If I save the GML from your link on disk and
run ogrinfo for the local file there is no error at all.
I used gdal-dev version from January 17th.
-Jukka Rahkonen-
