[gdal-dev] ogr WFS GML parse error with WFS 1.1.0
Jeremy Palmer JPalmer at linz.govt.nz
Tue Feb 26 16:05:13 PST 2013
> should be fixed by r25691
Thanks. That works when using SimplifyPreserveTopology :)
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
